I've had a decent amount of corrosion on positive side of battery post/cable. Twice in last couple of months. Could it be due to hooking up too many accessories to power outlet in cab, or something else?
    Have you put anything on the terminals after cleaning them to prevent corrosion? Grease works really well. Commented Jan 9, 2017 at 2:46
Extra accessories are unlikely to be a cause.
The corrosion is caused by acid mist escaping from the battery. it could be normal, or could be a sign of a faulty regulator in/on the altenator.
Check that the battery voltage, and electrolyte levels are normal.
I find a petroleum based jelly - vaseline works better for battery terminals to reduce corrosion compared to an ordinary grease. Having a tub in my tool box caused many mechanics to make dodgy jokes about why I needed that...
