First: Happy New Year for everyone :)
Help me please radio code problem. I have a car: Ford Scorpio mk2 1996
Model Number: 9000 Ford VNR / VNR Spring MNT Part Number: 1S7F-18K931-AA Serial Number: KAEM021238
There is this code? Possibly program? I could not find anywhere. If you can help please. It can be downloaded from somewhere in the CRUCC, or similar programs? Thanks Thomas Staviarszki regards from Hungary
    It sounds like your radio isn't working and is prompting you for a code. Is that right? The code usually (in the US at least) comes with the car and is specific to the particular radio – it is like a password and is supposed to help prevent stealing of the radio. If that is the original radio, you might be able to get the code from a Ford dealer. – dlu Jan 7 '17 at 17:54
    As @dlu stated. Here in the States I can take the VIN to the dealership and they can get me the code. I have to prove I own the car is the only stipulation. Some vehicles (Hondas are one I believe) will have the code written down in the owners manual. You may try there if you have the original manual. – Pᴀᴜʟsᴛᴇʀ2 Jan 7 '17 at 19:16
  • VW also provides the code in the original papers that you get with the car. I think there is also a spot to write it in the owner's manual. So, if you've got any of the original papers look through those. – dlu Jan 7 '17 at 19:31
You can generate Ford radio code easily from the radio serial number. All you have to do is to remove your radio and find the serial number starting with Mxxxxxx
In your case the serial number is : M021238
Your radio code is : 1471
