I have a 2003 Honda Accord (V6). I've read in the manual that I need to use Genuine Honda power steering fluid. Is this a must or can I use any power steering fluid. The Honda one has a reddish/pink color to it. Is the chemical make up any different than other power steering fluid? Is this a marketing gimmick from Honda?
You do not need to use "Genuine Honda" power steering fluid. You do, however, need to use power steering fluid made for Hondas/Acuras. If you look at any manufacturer specific manual, you'll see they will specify "genuine" this or that. This is a means to get you to purchase their products. Most often there are alternatives.
You cannot use just any power steering fluid in your Honda. There are several manufacturers out there who make it, such as Prestone.
I found a Prestone power steering fluid that says "for use in all manufacturers", so I don't need to get their Honda/Acura or Asian version, do I? Dec 24, 2020 at 23:00
@pacoverflow - Yes. It is specific to the Honda/Acura. You're better off getting what is needed then paying for an entire power steering system (pump/rack) because the fluid screwed up all your seals.– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 25, 2020 at 0:13
It doesn't look like the Honda/Acura version is carried by many outlets. It's not even listed on the Prestone web site. Can I use the Asian version instead? Dec 25, 2020 at 7:30
@pacoverflow - You can use whatever you want to use. I'm not here to dictate what your pocketbook can afford. I can only give advice. If you don't want to follow it, that is completely up to you.– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 25, 2020 at 11:36
1@pacoverflow - The Prestone bottle is just an example. There should be other brands out there which are available, including OEM Honda. I'm just saying, you need to use the Honda/Acura labeled stuff or you could be screwing up your system. Don't use generic fluid in it.– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 25, 2020 at 20:33
Honda genuine power steering fluid is different than other available choices. The formula is proprietary and not published. It was developed in the early 1990's to solve a significant chatter symptom in Honda power steering rack and pinon units. This problem was caused by incompatibility between the old fluid and the sliding seals on the rack sliding seals. It then became the go-to fluid for racks of other manufactures with similar symptoms. Others brands of fluids have caused leakage and chatter symptoms in Honda steering racks. It has a different blend of additives that are compatible with the elastomers (seals and hoses) used in Honda power steering systems. Some use it in all makes as it is said to be compatible with elastomers of all types.
Many vehicle makes use automatic transmission fluid for power steering system. This works most of the time but these fluids are optimized for clutch friction characteristics not sliding rubber seals.
Here is my take: - If you are flushing the power steering fluid, it is ok to use any other brand. Since you are not mixing two blends.
- But if you are just topping off and you don't know what is already in the system, then safest bet is to use the one from Honda dealer.
Use the Honda fluid. You'll kill your power steering system otherwise.
It is not the same, it is not a gimmick to make more money... in fact the Honda fluid was 4.75 from the dealer and the supposedly the same bottle by prestone was 9.99 at autozone.
totally different formula and weight. Use only fluid designed for asian systems or honda accura fluid. available form dealer, prestone and beck arnely.
The Prestone Synthetic Asian formulation power steering fluid for Honda is $6.99 for a 10 oz bottle at Walmart. I flushed my '06 Accord ps system with two bottles at 130K. Another few K and I'll flush it with another bottle. Also bought a case of DW-1 ATF for under $100. Drain and fill every 50K. Cheap insurance.
Never use other fluid than Genuine Honda power steering fluid. I'm being using Honda Accord 2.4 since brand new till now her age 11 Years, No problem towards my Power Steering pump or rack. It's proven to use Honda genuine parts or fluid for Power Steering, Transmission Oil, Engine oil, Brake oil may extend the life span of wear and tear parts.
