This morning (sunny weather, ~8 °C) I parked my Smart ForFour 1.1 (first generation, made in 2007, ~43000 km), left it there for ~20 minutes, then, when I started it again, it had the "motor check" light on and the engine had clear power issues:
  • when left idle, it stayed on the low side - ~900 RPM instead of its (IIRC) more usual ~1200;
  • it didn't respond well to the accelerator - left in neutral, even at full throttle it struggled to reach 4000 RPM, and it was as if the accelerator had an initial "dead zone" before actually doing something;
  • when trying to move, it had really low torque - I had to engage the clutch really slowly to avoid stalling the engine.
(as soon as I noticed this I switched it off and on to make sure that it wasn't some random electronic problem, but of course it didn't do a thing)
Now, I had to drive for - say - 4 kilometers in this condition, then I parked the car to check if there wasn't anything macroscopically wrong (refrigerant and motor oil in particular); after I started the car again, the "engine check" light was still on, but the power issues disappeared - now the engine feels exactly as usual.
Of course I'll bring it to a mechanic ASAP, but I'd be interested in opinions about what could have happened and, in particular, why is it now apparently working fine but the engine check light is still on.
Some extra details about the car: it's a Smart ForFour 1.1 (first generation, 2005 model, gasoline, 47 kW) - it has actually the same engine of some Mitsubishi Colt. It was bought in 2007 by a relative of mine who didn't use it much - I got it in 2015 when it had ~30000 km. I performed the regular 40000 km maintenance (oil change, air filter change) in June 2016; changed brake pads and passed bi-annual mandatory inspection in November. The only issue it had (two years ago) was some noise/slippage of the drive belt, which was replaced and later re-tensioned.
Update
Using an ODB2 reader and ODB Car Doctor I got the error codes:
  • P1961
    • Freeze DTC
    • Fuel system status (FSS): Open loop: engine load OR fuel cut due to deceleration
    • Calculated engine load value (EngineLoad): 31.37%
    • Engine coolant temperature (ECT): 63.0 °C
    • Short term fuel % trim Bank 1 (STFT1): 0.0%
    • Long term fuel % trim Bank 1 (LTFT1): 1.56%
    • Intake manifold absolute pressure (MAP): 32.0 kPa
    • Engine RPM (RPM): 832.0 rpm
    • Vehicle speed (Speed): km/h
    • Timing advance (TA): 9.0°
    • Intake air temperature (IAT): 34.0 °C
    • Throttle position (TP): 5.09%
    • Distance traveled with malfunction indicator lamp (MIL): 14.88 km
  • P0122: Throttle/Pedal Position Sensor/Switch "A" Circuit Low
Reading around it does seem to be a very common problem related to the throttle body - it either needs cleaning or replacement; can someone confirm? How would I go to clean it up myself? I don't really know even where it should be located...
  • By the way, someone with more rep should create the Smart tag - for the moment I tagged it with Mitsubishi (the maker of the engine and most other parts shared with the Colt) and mercedes-benz (commonly associated with Smart, but not really involved in the first-gen ForFour), but still feels wrong. Dec 31, 2016 at 14:38
  • Welcome to the site. Usually we suggest getting the codes read. This will give you the best shot at what's gone wrong with the vehicle. The reason the CEL is still on is because something was wrong with your car and the code is still present in the system. Your best bet is to have the code read, then clear the codes, then see if the issue comes back. Until you get the code read it's anybody's guess what happened. Dec 31, 2016 at 14:45
  • @Pᴀᴜʟsᴛᴇʀ2: actually I asked a friend of mine to lend me his ODB2 reader, I'll be able to try it tomorrow afternoon. Dec 31, 2016 at 14:50
  • Still, this really looks like it: evilution.co.uk/707; tomorrow I'll check to see if I get a P0122 error code. Dec 31, 2016 at 15:03
    Sounds reasonable! If you find this is the issue, please answer your own question. As with all SE sites, we love to accumulate knowledge :o) Dec 31, 2016 at 15:05
Very late reply because it slipped from my mind at the time: ultimately it was the throttle valve that needed some cleaning. The problem is mentioned at https://www.evilution.co.uk/707, but I didn't need to be so thorough and remove the cover and clean the cogs, cleaning the valve itself was more than enough, as mentioned also all around on the ForFour.co.uk forums (search for TVA).
There's a full guide here (don't know if I'm allowed to repost their content, so I'm just linking it); it's actually quite easy and, for a rough cleaning, there's no need to remove the TVA from the engine: it's enough to disconnect the air intake pipe (the big rubbery pipe connecting the air filter box to the TVA, which is screwed to the bulk of the engine), and then cleaning the "entrance" of the TVA with a cloth, keeping the butterfly valve opened either with a finger, or having the key in the on position and someone pressing the accelerator pedal - with the engine off of course.
