Car: 2006 scion tc
So the other day I had a problem, as I was driving, I hit a hard bump, my passenger side tie rod then fell out (I assume it wasn't screwed in correctly from the last time it was replace) my right tire then turned all the way to the left and I skidded to a stop. After, I inspected the tie rod, it looked good with no signs of damage, the inner and outer part were still locked in position by he nut, and the threaded ball joint that screws into the steering rack looked fine too. I screwed the tie rod back in, tightened everything down so I could drive it home down the street, but I realized the alignment was way off. When my steering wheel was in the middle it would veer to the right, only by turning the wheel about 15 degrees to the left I was able to go straight. I checked the alignment by sight and realized when the steering wheel was centered the right wheel stuck out to the right by about 5 cm or so. My question is, even though the inner and outer tie rods seenmed to be in the same place after it popped out, why would my alignment be off? Could there be any other thing affecting it at all? Thank you, feel free to ask for clarification if I may not have explained anything enough. Also the pic shows how the passenger side tire sticks out about 5cm to the right when the wheel is centered, compared to the drivers side which is straight
