I have a problem with my malibu, I got a code on the obdii reader as though the coolant temperature reading is not correct, so in the car lcd on the instrument cluster I can see Coolant temperature : -- C. The problem is through my OBDII, I am able to get a reading from the ect sensor which seems correct and makes sense. Has anyone experienced this problem before ?
2Which engine do you have in your Malibu? 2.4, 2.4 Hybrid, 3.5, or 3.6?– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 17, 2016 at 16:11
It is the hybrid model ! 2.4 ecotec– Omar KhoaliDec 18, 2016 at 1:44
1what's the code? can you communicate with the instrument cluster module?– BenDec 20, 2016 at 19:21
Sometimes when your coolant temperature sensor goes bad then it can send a false signal to the computer. It may have sent a false signal– wilkvolkAug 14, 2020 at 23:26
