I have an '01 Durango that has a power drain. I hooked up a meter on the negative side and it showed 12.3. I started pulling fuses from both fuse panels and didn't see a drop. I disconnected the positive cable from the fuse panel and the power drain dropped off to 0.2. What can cause this and what should I do to fix it?
1I've got some questions: What problem lead you to start investigating the drain? Is the 12.3 a voltage or a current reading? Where did you connect the meter (to the negative side of what? where was the other meter probe?).– dluDec 12, 2016 at 1:15
Disconnected the neg side of the battery connected the meter between the cable and the post and its voltage– Wade ChristensonDec 12, 2016 at 1:34
So, I think back to the first question of my comment above – can you tell us what lead you to start investigating this?– dluDec 12, 2016 at 5:39
Battery kept being drain when sitting new battery charge it up and three hours later dead– Wade ChristensonDec 14, 2016 at 1:24
Does the battery hold a charge if not connected to the car?– dluDec 14, 2016 at 1:45
1 Answer
This is not a power drain, this is normal. Your battery will sit at ~12.4 V with the car off. You can pull out all the fuses in the world, you can even take the battery out of the vehicle and carry it a full mile away from your vehicle, it will still read ~12.4 V.
If you are really investigating a power drain, you need to measure current, not voltage. Repeat your procedure (you were doing the right thing), just switch your meter to DC amps.
Also, make sure that you're on a suitable scale. The normal draw when the car is turned off will be a few 10s of milliamps. Most meters with an amp scale can measure this, but if the draw is large you may blow a fuse in the meter if the you're on the wrong scale. Many meters have three jacks for test leads, one often on the left, is for a higher amp range. Start there so that you don't end up having to look for a new fuse…– dluDec 12, 2016 at 5:42
