I recently had the aux drive belt fail on my SAAB 95. Because the alternator was then not running, the electrics all slowly died as the battery ran flat. As I was stopping I shifted into neutral and there was a "clunk" so I shifted back into Drive and there was another "clunk".
The drive belt is now repaired but I have a warning light for "Automatic Transmission" (a yellow gear wheel with an exclamation mark inside). The car drives fine and I don't think there's anything actually wrong at this point. Would this warning just linger until manually cleared? Is there a way of resetting it?
Update: Sorry, I forgot to mention: the battery has been disconnected for at least 3 days while I recharged it off the vehicle. The light is still on when I reconnected the battery. It came on immediately on turning the ignition on and before starting the engine.
