22
When you come to a stop with a manual transmission you have to push the clutch in or take it out of gear to keep the engine from stalling out. What keeps the engine from stalling in an automatic transmission. Even when I rev the engine while holding the brake the engine won't stall out, I can tell the car is in gear because it's trying to move forward but the engine stays running. If I tried this with a manual transmission the engine would stall
  • Eric the Car Guy has a YouTube video about Torque Converters that explains this really clearly with a neat demo, using two household fans. The demo starts at about the 5 minute mark, and the "wheels braked but engine running" bit is at 6:20 or so.
    – jscs
    Aug 16 '13 at 18:45
  • Wow, I should have know that before. I had a Sunfire 2000 which stalled sometime when stopping...we changed pretty much everything even the engine but now I think that this part could have been the source.
    – Zonata
    Aug 17 '13 at 14:51
29
The reason that an automatic doesn't stall out while "in gear" and at a stop, while a manual transmission does, is that automatic transmissions use a hydraulic torque converter to connect the engine to the transmission, while manual transmissions use a friction clutch. These two systems do a similar job in a very different way.
A torque converter uses fluid to transfer the power, and so it can "slip," effectively disengaging the engine from the drive wheels at low speeds. When you come to a complete stop in an automatic transmission car, the torque converter starts slipping, allowing the engine to keep turning even though the wheels have stopped.
The only way to get the friction clutch of a manual transmission to slip is to depress the clutch pedal. If you come to a stop in a manual transmission car without depressing the clutch pedal, the engine stops turning when the wheels stop turning, and the car stalls.
See Wikipedia's articles on torque converters and clutches for a more thorough treatment.
  • There is still slippage, ie energy lost as heat and wear and tear. Is it better to put the gear in N when stationary?
    – Old Geezer
    Oct 8 '15 at 1:33
  • @OldGeezer only if you play to rev the engine up (to impress your friends!). If you aren't touching the accelerator and are stopped, e.g., at a stop line or traffic light then it is fine to leave the transmission in drive.
    – hddh
    Oct 19 '15 at 8:01
  • None of our two automatics have torque converters. Feb 15 '16 at 23:28
  • @hddh If you're revving the engine to launch, it's actually better to leave it in gear - the torque converter can take the pressure increase fine but dropping it into gear from neutral at high RPM puts a lot of stress and wear on the gear selection bands. That said, if you're trying to launch the car... probably should have gotten a manual in the first place ;D
    – J...
    Mar 4 '16 at 15:10
15
It is important to note that revving the engine on an automatic transmission car while holding the car stationary with the brakes causes premature transmission wear and early failure. This action causes the fluid to overheat. It also damages the torque converter and driveshaft or cv joints.
If you look at advertisements for performance torque converters they will mention antiballooning,furnaced brazed fins and roller bearings. These are all needed if you want to abuse the drive train by stalling the transmission with the brake. By pressing the brake and the gas pedal at the same time it is possible to spin the tires. The technique is as you described.
  • I merged this from the previous question because the content is useful. However, it does need a rewrite in its new location.
    – Bob Cross
    Jul 13 '12 at 16:27
