few days ago suddenly my bike low beam stop working and its always showing high beam.I already change the indicators panel but issue is same. Whenever I switch on the lights, its gone on high beam and even I am not able to us dipper which creates issue on the night time.please help asap
  • The low beam filament on your build might have blown out, Replace the bulb.
    – Shobin P
    Nov 16 '16 at 11:26
This seems like a case of buld malfunction, but since you say that you're not able to use dipper too I would recomment checking output at the bulb holder. and then make a decision accordingly.
It might be because your lowbeam bulb is fused.have it checked,if it's fine then the problem will be with the dipper switch and you will have to get it changed.
