I'm looking for info on tailgate struts that are electric / hydraulic hybrids -- they accept a DC voltage from a control module to open, then close when +/- are flipped, with the action mediated by internal hydraulics. There are built-in sensors to (I presume) detect limits and pinches.
The one I'm dealing with is used by Land Rover, but I assume the notion is not unique to them.
This is not for a repair, but for a demo buck. I don't have access to the control module and need to mimic its behavior. The connections named are power +, power -, Hall power, Hall ground, Hall sensors 1 and 2
, but no other data is available, including pinouts.
Any information would be welcome -- manufacturers, sources, specs, internals, etc. The wide wonderful web doesn't seem to have any info, or I just don't know what search terms to use.
