Before I ask the question a couple of things:
- I'm able to drive my car normally
- I'm driving the vehicle on a daily basis, taking it to work and then to back home again.
The problem that I have is while releasing the clutch. It doesn't matter what gear it is in, or you could keep the car in neutral and still this problem would happen.
What happens is that I have pressed down the clutch fully (100%) and then slowly start releasing it. While releasing the clutch somewhere around 70% it suddenly gets released immediately. It's like the area between 70%-10% is pretty loose and the clutch moves freely. The resistance is not uniform.
The odd thing is that this "free-movement" issue starts even before the biting point is reached, continues through the biting point and a little more.
What could be the reason for this? It's a Maruti Suzuki Wagon R Duo LXi LPG. It has a cable clutch.
