1985 Chevy Camaro Z28 5L 5 Speed Transmission
More times than not, when I turn the key to start, there appears to be no power. No dash lights, dash gauges don't move, radio doesn't come on, headlights, horn, and flashers don't work. I've checked for loose or damaged wires but have found nothing. Does anyone have ideas on that could be wrong?
ON
position?Start
usually cuts power to everything while the starter is engaged. Is that what you are saying? – CharlieRB Nov 7 '16 at 19:24
