I'm still working on getting this EG33 into a 96 Impreza. I have received some wiring harness diagrams, but am unable to match them to the ECU which is in the car. I'm wondering if what I have are the correct diagrams. Here is what the ECU, connector, and plug looks like:
I have the following wiring diagrams, which are supposed to be for the 96 Impreza. I'm not seeing how it marries up to the above connections:
If someone could help me rectify the plug to the diagram, that'd be awesome. Or, if I have the wrong diagram, it'd be awesome to get the correct ones. And before you ask, I was unable to match a colored wire to something on the plug. Specifically I was looking at wire 32 on the ECU (or could be ECM per what's on the diagram). It shows to be LgB, which could either be light brown or light blue. I couldn't match this with a corner pin on the connector anywhere. At least I'm assuming it should be on a corner somewhere due to where it's at in the diagram.
