On my '95 Acura Integra LS, the driver's side outer tie rod is embedded in the steering knuckle. I am unable to loosen the jam-nut.
How do I remove the outer tie rod from the steering knuckle?
This photo shows that upward force applied by jack is insufficient to remove the outer tie rod. (The vehicle has been properly secured on jack stands.)
Follow-up: How to unscrew inner and outer tie rods?
