I have 3 Ford vehicles: a 2001 Taurus, a 2006 Taurus, and a 2008 Explorer. All of them have V6 engines. The check engine light for all 3 comes on at times.
If I use gasoline without ethanol, the CEL usually turns off within the first tank. But, when I switch back to gasoline with 10% ethanol, the CEL eventually comes back on.
Anyone have any ideas or suggestions?
    Have you ran a scan to see what codes are present? – Pᴀᴜʟsᴛᴇʀ2 Oct 30 '16 at 22:52
  • As @Pᴀᴜʟsᴛᴇʀ2 says the answer or at least a good clue will lie in the codes that go with the CEL. Without them we're guessing, educated guesses perhaps but still guesses. – dlu Oct 31 '16 at 0:21
  • Does the brand of fuel with ethanol matter? How long does it take for the CEL to come back on when you start using ethanol again? – dlu Oct 31 '16 at 0:28
  • This is much more likely to be an evap. system code that goes away with a full tank. – Eric Urban Oct 31 '16 at 3:23
  • i'd say it would be a rich code what's the engine vin code? u? – Ben Oct 31 '16 at 10:57
