I bought a used Triumph Street Triple from 2015 and suspect the clutch friction plates are worn down.
Before I open it up, I might as well buy the plates since they're not expensive and I found these ones on ebay claiming to fit Street Triples from 2007-2012. My question is, did they change the clutch for the 2013 model or can I use the same ones?
  • I, like you, am not finding any clutch related parts listed for 2013+ ... I'm wondering if these have not hit the streets yet due to warranty replacement. You don't usually find aftermarket or replacement parts for vehicles of whatever type until warranties start expiring. – Pᴀᴜʟsᴛᴇʀ2 Oct 30 '16 at 14:33
  • Seems premature. How many miles are on that clutch? What makes you suspicious the plates are worn? Have you ensured it is adjusted properly? – CharlieRB Oct 31 '16 at 15:41
The 2015 is a reworked engine
The 2015 Triumph Speed Triple engine is a bit different from the 2012. Different cams, crank, connecting rods, pistons, etc.
The clutch plates in the 2015 are a bit larger in diameter.
The clutch plates you found may barely fit but I would not use them. They are different part numbers.
