In my 2014 Hyundai Elantra, I can hear what sounds like water spilling out by the drivers side dash.
I pulled in the driveway, sat for a moment, and heard it.
I had the defroster on the first time I heard it. I then turned it off and could still hear it. I left the car on and checked the fluids under the hood, but obviously couldn't see anything. I turned the heat off and sat idle for 15 more minutes and can still hear it.
What is causing this? How should I fix it?
  • Possible duplicate of Sloshing Sound Under Dash – CharlieRB Oct 28 '16 at 14:50
    @CharlieRB That question is about a sloshing noise when stopping and starting. This question has a "spilling water" sound while stationary. – Zach Mierzejewski Oct 28 '16 at 15:16
  • The other post talks about a sloshing when the car accelerates. This is when the car is at idle. – anonymous2 Oct 28 '16 at 15:17
    Lol. I agree with Zach. ^^ – anonymous2 Oct 28 '16 at 15:17
  • You are correct. That is why there is voting. If you don't agree it is a duplicate, that is your opinion. Notice the comment says "possible" duplicate. It does not say "absolutely" a duplicate. My single opinion does not have action in itself. +1 for agreeing with each other? Really? – CharlieRB Oct 28 '16 at 15:23
I am not familiar with your specific vehicle, but I have encountered similar issues when all there was air in the cooling system.
The heater and defroster works by using a heater core which is like a little radiator that sits under the dash, then a fan blows air over it to heat the car. The biggest problem is that this heater core can sit pretty high compared to the rest of the cooling system and it is easy to trap air in it. What you are hearing is most likely the sound of water moving through a larger air pocket that is stuck in there.
The first thing to check is how much coolant you have right now. But only open it when the engine is cold! In your description you said that you did this, but did you just look at the overflow bottle or take the radiator cap off?
If that looks OK then you need to look up the purge procedure for your car. One of mine actually wants you to jack the front up and push a couple of buttons on the HVAC unit when starting it to put it into "Purge Mode. Most of the others I have are just, turn this little screw and let the air out sort of things.
Once the air is out you should not hear anything as the water moves through the pipes.
As an aside, turning the heater off does not necessarily prevent water from circulating through the heater coil, many don't regulate it or use a fixed thermostat independent of the heater settings.
