I am using Yamaha FZ. Sometimes in morning, the bike is not start with electric as well as kick start. When i put it in gears and tried to move the bike, it will move like neutral gear. If I move the bike long with gear the friction inside the engine become increase and engine may starts.
What is this issue?
How can we repair this issue?
Model : 2012
Engine type : Air cooled, 4-stroke, SOHC, 2-valve
Displacement : 153.0cc
Bore & Stroke : 58.0mm x 57.9mm
Compression ratio : 9.5 : 1
Maximum output : 14PS@ 7500 rpm
Maximum torque : 13.6 Nm @6000 rpm
Starting method : Electric and kick
Lubrication type : Wet Sump
Fuel Supply : Carburetor
Clutch type : Wet, multiple-disc
Primary/secondary reduction ratio : 3.409 / 2.857
Transmission type : Constant mesh 5-speed
Gear ratio : 1st=2.714 2nd=1.789 3rd=1.318 4th=1.045 5th=0.875
Cylinder layout : Forward-inclined Single Cylinder
Battery : 12V, 5.0AH
