I need to work on the inner rear light cluster. How do I remove the lining from the boot lid? I'm assuming this is the way to access the lights
  • Can you take a picture? Are the obvious places for screws? Even if there are screws or bolts trim is usually held on by clips. Is it cardboard/felt/whatever trim? It may just be held in by plastic pins.
    – Ben
    Oct 19, 2016 at 23:30
