I was replacing my upper control arms today, however the manual I simply stated "tighten" the bolts (they're meant to be self-locking). So after some googling my car model (Audi B8 A4/A5), I wrongly thought I should tighten them to 90nm (first tried 40nm as I saw, but it didn't seem tight enough). The torque wrench never clicked, so I kept tightening them. I then reduced it to 70nm, and it finally clicked, and I stopped.
Now, thinking about what I did, I did more googling and it turns out the bolt should've been tightened to 40nm + 180 degrees stretch.
Here's a picture I took of the original set up:
And after (note there's no gap between the pinch weld)
So my questions are:
  1. Is it possible to fix what I have done?
  2. If so, how?
  3. How badly did I mess up my car?
  4. Should I use a new bolt and nut?
Thanks.
Update: Tried to take the thread out, got it about an inch out, then it just started spinning. Had to call a thread repair specialist to pull it out. The bolt was completely deformed. Slightly widened the pinch, and used a new nut and bolt and tightened to spec. All looks well (for now).
7
Replace bolt and nut
Likely, there's no damage to the control arm. 70 to 40 is a big jump, but not likely extremely damaging, in my opinion. However, I would definitely replace the bolt: putting that much strain on it risks reducing the bolt strength such that it could break while you're driving.
Replace the bolt, and while your at it, replace the nut as well. How much does a bolt actually cost, after all? Another one of my famous mathematical equations:
cost of (future suspension damage + time getting fixed) > cost of bolt
  • No issues with using a new nut and bolt, my main concern is with the actual pinch section of the metal strut. The manual said while removing, you must never pry on the pinch. Because I overtightened it, is there a good possibility I have pinched closed the gap, thereby making it very difficult to remove the ball joint in the future?
    – tgun926
    Oct 19, 2016 at 12:29
  • That is a possibility. I'm kind of a rough and tough it mechanic: I would just try prying the pinch very carefully in spite of the manual. Not more than once, mind you.
    – anonymous2
    Oct 19, 2016 at 12:31
  • You have to beware of metal fatigue, of course. If you can heat the metal somewhat before prying, that would be better, and if you really have to pry it far, it would be best to replace the entire strut. IMHO, mind you.
    – anonymous2
    Oct 19, 2016 at 12:33
  • For sure replace the pinch bolt, might be really fun getting it out. Once pulled inspect the UPRIGHT very closely for any cracks. Oct 19, 2016 at 18:22
  • @spicetraders Yes, was great fun. I had to call a thread repair guy to come take it out, the bolt was completely deformed and stuck.
    – tgun926
    Oct 22, 2016 at 1:27
