I'm wondering what this part is called? My headlights stopped working so I pulled the dash panel under the steering wheel and found this part was corroded and burnt. Please help me out! Headlights won't turn on
That is called a headlight switch connector. :)
Thank you! Anyone know if there is a discount website I could find one at? – Kyle Sarate Oct 17 '16 at 13:48
1I would check junkyards. I remember hearing from someone that worked at a dealership that the switch burning up wasn't uncommon and the fix was to relay the headlights. – rpmerf Oct 19 '16 at 12:14
1Consider ch3cking the switch as well. If you have that much damage on the connector, the switch is likely damaged too. – Paul Dufresne Apr 12 '17 at 4:27
