I have a Yamaha YZF600 which was running well. I began to have issues starting and had to jump it a few times, so I replaced the battery. After a couple of weeks I finally got the battery and charged it. Now, I have no power.
I get no power to the dash/lights/signals/horn. The only thing that lights up is the green light that indicates I'm in neutral. I have had the battery checked, and it's fine.
Any suggestions would be appreciated. Thanks.
    I would possibly think either the ignition switch or you don't completely have the battery attached fully (semi/loose connection at the battery post). – Pᴀᴜʟsᴛᴇʀ2 Oct 15 '16 at 15:12
    Could be a ground issue, the neutral light gets it ground in a separate wiring line then the ignition module and lights. – spicetraders Oct 15 '16 at 15:33
  • @chris What year is your bike? – DucatiKiller Oct 15 '16 at 20:09
  • It is a 1998... – Chris Oct 16 '16 at 17:22
  • Even though the battery is new, have you had it tested? – DucatiKiller Oct 17 '16 at 4:36
