I have a Holden Cruze 2009 CDX. I have discovered a leak coming from ky oil filter and its lnding on the exhaust pipe causing a light oil smell. I also have an engine warning light that displays, my question is, would an oil filter leak cause the engine light to come on? Thanks
    Which engine light, the Check Engine or the Check Engine Oil light? – anonymous2 Oct 7 '16 at 12:22
  • Its the orange check engine light – Elevant Oct 7 '16 at 21:03
Oil dropping on the exhaust pipe does not normally cause any warnings on the engine management system. If the oil leak is from the filter seat then tighten it. If tight try undoing and putting some grease on the seal then tightening. If the car has oil on the dipstick then take it to your friendly mechanic to have the fault codes read from the computer.
| improve this answer | |
