This knob in an old trailer of mind broke off. Is it possible to replace it?
I'm curious if the aluminum "thread" that inserts into the knob has a name or standard. You can see what I mean in the first picture.
Sign up to join this communityThis knob in an old trailer of mind broke off. Is it possible to replace it?
You can be certain that the thread is a standard size. Take the screw or a similar one to a hardware store and they will help you find a matching one.
As was mentioned in the comments, the attachment looks very much like a standard window crank. I would bet that a search on Google or the like would turn up some sources.
I would try to use Round Valve for plumbing. Something like this and bolt it down really well for a tight fit. To secure the fit, may be even use liquid nails or solder it to the male piece.
