I have a question, if i have many codes from my ELM 327 OBDII, Mass sensor, Km traveled, Lambda, Temp, fuel pressure, gallons x time, engine load.... hao i can calculated these emissions?
No, it is not possible to get true values from OBD-II ELM327.
You have to have a dedicated exhaust gas analyzer to figure that out, like this one:
But you can estimate it using a lambda sensor
Although I fear that the theoretical graph is not going to be very useful in the real world:
Thanks! I´ll try with these information, i know is not easy but maybe this formula exist, – Rafael Angel Monzon Pingarron Sep 28 '16 at 14:50
If I'm interpreting that chart correctly, looks like you'll especially have issues calculating backwards for richer mixtures, where the O2 curve flattens out. – Jason C Sep 28 '16 at 14:56
