Please help, should i get a tune-up. I will post a video, so y'all can get a better idea of the issue in the car. Please visit link to get an idea of the issue.
1Pull the intake tube off the throttle body and take a look at the plate. Is it dirty? Has the battery gone dead recently? I doubt a tune up will fix your low idle and rev hunting issues. – Ben Sep 26 '16 at 20:55
Thanks man, ill attempt to do that. i have very basic mechanic skills but i have a very low budget so i don't have time/ resources to do much then to take it in. – Leonardo Casita Sep 26 '16 at 21:55
Is the CE light on? – method Sep 27 '16 at 0:44
Also check the engine bay for vacum tubes, check to see if everything is connected – method Sep 27 '16 at 0:45
It appears to be trying to keep the beat. (-: On a serious note, many things can cause engine surge. This article, The dreaded engine surge, has some helpful tips on what to check. Other than that, due to lack of details, this is too broad of a question. – CharlieRB Sep 27 '16 at 17:28
Add a comment
