2007 Vibe, starts with remote start but does not start with key. This started after replacing dead battery a few months ago. It is as if it does recognize the is there. Not sure what to check.
    does the security light flash when you try to start it using the key?
    – Ben
    Sep 26, 2016 at 20:57
  • When using the key, does the engine turn but not run? Or is it simply nothing when twisting the key to the start position? Also, is it factory remote start or aftermarket?
    – CharlieRB
    Sep 27, 2016 at 17:56
