7
I just took my car to get it aligned and all numbers came back within standards, at least according to sheet given to me at the facility, with the exception of one: Cross Camber. I will try to add all numbers here for reference:
Front Left:
           Actual   /  Before   /   Specified Range:
Camber     -1.0     /  -1.0     /   -1.3   -  0.3
Caster      4.9     /   4.9     /    4.2   -  5.7
Toe         0.04    /   0.23    /   -0.03  -  0.13
SAI        13.0     /   13.0    /    12.0  -  13.5
Inc Angle  12.0     /   12.0    /    10.8  -  13.8
Front Right:
Camber     -0.6     /   -0.6     /   -1.5   -  0.0
Toe         0.06    /    0.38    /    -0.03 -  0.13
SAI        12.6     /    12.7    /    12.0  -  13.5
Inc Angle  12.0     /    12.0    /    10.5  -  13.5
Front:
Cross Camber** -0.4 /   -0.3     /   -0.3 - 0.8
Cross Caster    0.0 /    0.0     /   -0.6 - 0.6
Cross SAI       0.4 /    0.4,
Total Toe      0.10 /    0.61    /   -0.07 - 0.27
Rear Left:
Camber       -0.7   /   -1.6     /   -1.1  - 0.1
Toe          0.08   /   -0.08    /   -0.13 - 0.38
Rear Right:
Camber       -0.7   /   -1.3     /   -1.1 - -0.1
Toe          0.05   /    0.08    /   -0.13 - 0.38
Rear
Cross Camber  -0.1  /   -0.4
Total Toe     0.13  /    0.00    /    0.00 - 0.50
Thrust Angle   0.01 /   -0.08
** (Note here how the actual worsened from the Before...Is this OK??),
Any help understanding these numbers will be greatly appreciated, especially that Cross Camber result for the front that was shown as the only number NOT within specification. Thank you.
7
Cross Camber is the difference is camber between two wheels. In this case your front wheels. If both wheels are set the same, the cross camber zero. In your case the front left camber is -1.0 and the front right is -0.6.
Notice in the camber specs that the two sides of the car are not the same. Camber controls the tendency of the car to "self-steer" (much like leaning a bicycle or motorcycle causes it to turn). Since most roads have a crown to them a bias in the camber based on the side of the road the car is intended to be driven on will result in less tendency to drift "downhill" towards the edge of the road. Cross camber is the measure of that bias.
The car will tend to "pull" (or in this case it might be more accurate to say compensate) towards the side with the more positive camber.
The claimed spec for the cross camber is -0.3 to 0.8 and yours is slightly out of spec in terms of the overall difference between the front wheels even though both front wheels are in spec. So it may have a bit more of a tendency to pull to the left than if it were in spec.
  • Thank you. My concern is: is the fact that the Front Cross Camber is not within specifications end up negatively affecting tire wear, handling or safety of the vehicle? I also read that Cross Camber is the sum of both the left and right cambers (1.0-0.6=0.4). Consequently, I found it weird in these numbers that both the front left and right cambers had the same exact numbers before and after but the cross camber changed on the after...is that normal/correct? How much is a cross camber difference of 0.1 degrees? Thank you! – Coamex Sep 24 '16 at 19:04
  • The change may be due to rounding – the equipment may be measuring to hundredths of a degree and rounding. With both wheels within spec I would expect little impact on tire wear due to the cross camber error. If you drive mostly on 2 lane roads with typical crown you might notice needing to carry a bit of steering correction and a tiny bit more tire wear. On the other hand if you mostly drive in the "fast" lane on divided highways you might notice less need for steering correction. Personally, I'd want it to be right, but I don't think it is a big deal. See how the car drives in real life. – dlu Sep 24 '16 at 19:20
