My 1998 Honda Civic Ex driver's side rear drum brakes make a "click click click" noise at low speeds only when brakes are applied.
All new hardware, shoes, and drums. Only thing not replaced are the backing plates.
Noticed when looking for anything that could be causing it that the shoe doesn't sit centered like the others. I can push it down but soon as brakes are applied it goes off center again (mating point slightly higher on the cylinder than the other shoes)
Any ideas why? I'm guessing this is causing the click noise as I don't see anything else it could be
