I recently had an LPG system installed in my Golf MK4 and now the car has some hesitation when accelerating. The mechanic who installed the LPG System told me that I need to change my current (cheap, but brand new) spark plugs for some new ones with platinum electrodes. Now I'm searching on eBay but there are silver or platinum models. On some forums I found claims that the silver ones are better.
Can anyone explain which ones I should choose and if it can be something else that causes that problem before I spend about $50 on new spark plugs.
  • Apology for your English accepted, but really, your English is just fine. More than understandable (and way better than my anything else). Welcome to SE Mechanics!
    – dlu
    Sep 17, 2016 at 17:10
Platinum is going to work best in this application, because platinum will stand up to the rigors of the LPG better. Iridium would work even better. There are several other types which would work even better, but if cost is a main factor, platinum will work pretty well.
There are other considerations you need to take into account, though, as well. I found this page from NGK which explains a few things about how to pick a plug for an LPG conversion:
LPG Compatibility There are two critical factors that need to be understood when converting a vehicle from petrol to LPG:
  • LPG burns hotter
  • LPG increases the voltage requirement at the electrode gap
In an attempt to correct these two factors, as a general rule we suggest to:
Use a spark plug that is one heat range colder than standard to compensate for the increased heat from LPG:
The temperature profile of an engine may vary between vehicles. As such, the effect of LPG on the operating temperature of one vehicle may not be the same for another vehicle.
For example, lets say that LPG increases the average operating temperature by 200°C. If the average operating temperature of a Holden Commodore (which uses a 6 heat range) was 700°C the addition of LPG would exceed the operating range of 870°C. As such a colder plug may be required. However, a Ford Falcon for example (which also uses a 6 heat range) may have an average operating temperature of 500°C, the addition of LPG is still within the 450 – 870°C operating range and a colder plug may not be required. Please note that these values have only been used for illustration purposes.
Reduce the electrode gap of conventional nickel spark plugs by 0.1mm to compensate for the increased voltage:
It is difficult to gauge exactly how much the voltage requirement has changed as other factors such as engine wear, loss in compression and ignition system weakness for example may provide an influence. As such the electrode gap may need to be adjusted several times until the correct gap setting is achieved for that unique vehicle.
Unless the vehicle is a production vehicle designed for LPG, the installation of LPG results in a modified engine. As such, it is the end users responsibility to ensure that the engine components have been considered and altered if necessary to allow for the modifications.
Since I don't know your the complete information on your vehicle, I cannot tell you exactly which plug to use in your application, but with this information you should be able to figure it out for yourself. The main thing to remember, this is not a one-for-one swap ... you should not be using the plug which was specified for your vehicle when it was using petrol.
    OK, this is more that I was expecting for an answer. You're the man, have a good day! Sep 17, 2016 at 11:32
I wouldn't use Platinum, it's not recommended on LPG, either copper or Iridium, as Platinum wear out quickly and cause issues on LPG fitted cars.
