My car will not start. A month ago it wouldn't start. At that time it was still cranking (weakly) but not starting. I bought a new battery and installed it. It still wouldn't start until I jumped it (which doesn't make sense since it's a new battery) and then it started. I took the old battery back and the worker said that the battery was fine. Keep in mind this was all a month ago and it was running fine until now.
It stopped starting up again. I did notice that the starts were getting weaker just before it stopped starting again. This time I had to get it towed. Now it will not crank at all and makes a single click and nothing more. Is this indicative of a bad starter or a bad alternator or is there something else I'm missing? All my electronics still seem to work fine, it just won't start so I'm leaning more towards the starter.
Vehicle is: 2006 Honda Civic EX 1.8L 4 Cylinder (though it shouldn't matter).
I did do a search and could not find any questions with this specific case.
UPDATE: I put in a fully charged battery (battery tested good and was charged using a battery charger) and it would not start. Like I mentioned before, a month ago it did crank (weakly) and wouldn't start. Now it doesn't crank at all and just clicks. Is this solely a problem with the starter or could this be indicative of an underlying problem?
UPDATE 2: It was the starter. It was going bad and would fail when it got hot.
7
    It won't start now even with a jump start? Sep 14, 2016 at 0:24
  • My friend jumped it for me but I knew he wasn't doing it right and he was very certain he was doing it right. Since he was helping me and could get me a free tow (he has AAA) I didn't want to argue with him. I'm going to attempt another jump today. If it jumps then I'm assuming the alternator is bad. I find it weird though that it needed a jump after getting a new battery.
    – Mocking
    Sep 14, 2016 at 0:27
    Just because it's a new battery doesn't mean it has a full charge. As a battery sits on the shelf, it will lose about 5% charge each month. It should have recharged after the vehicle started, though ... given enough time. Sep 14, 2016 at 0:29
    @Pᴀᴜʟsᴛᴇʀ2, right on, though enough time could be several hours.
    – anonymous2
    Sep 19, 2016 at 11:59
  • @anonymous2 - exactly my point :o) Thanks for helping clarrify. Sep 19, 2016 at 12:01
3 Answers 3
7
To differentiate between the starter and the alternator you can check the battery voltage – should be about 12.6 with the engine off and 13.5-14.2 with the engine running if the alternator is doing its job.
You may have a failing starter. You can get a good take on this by taking a current reading while trying to start. Usually this is done with a specialized meter, so you may want to take it to a motor shop or a car parts store and ask them to test it. A failing motor will usually have a very high draw (or none).
However, if the car won't move… The starter should cause a large drop in battery voltage when it runs (and even more if it doesn't run, but is trying to). So if you have access to a volt meter you could also try reading the voltage before and during an attempt to start. Any significant drop in voltage indicates that the motor is trying to run. If it isn't then I'd say it's time to take the motor in for repair/replacement.
11
  • Not to be snarky but I'm not sure how to get my car to an parts store since it won't start... any ideas? I'd prefer not to have to tow again. I do have access to another car though.
    – Mocking
    Sep 14, 2016 at 0:28
  • 5
    You can take the battery/alternator individually to the parts store and have them test each for you. Your trusty friend who doesn't know how to jump start a car might be just the person to give you a ride! Sep 14, 2016 at 0:31
  • Fair enough, you may be able to infer current accurately enough from the voltage drop when you try and start it to tell. The starter puts a huge load on the battery and the voltage will drop a lot if it is trying to spin. If you see that and the starter isn't running that's a pretty good sign the starter is the problem.
    – dlu
    Sep 14, 2016 at 0:32
    Pretty unlikely, I'd say. There aren't too many ways that the engine can even get at the starter, let alone damage it so that it won't spin – at least not that I can think of.
    – dlu
    Sep 17, 2016 at 1:21
    @anonymous2 I figure i'd let the days run down incase someone else wants to take a stab at an answer even if my problem is solved.
    – Mocking
    Sep 20, 2016 at 22:05
+25
There's a potential third posibility, which is the positive battery cable to the starter.
In order to evaluate this, you should perform what is called a voltage drop test on the cable, using a voltmeter connected between the positive battery post, and the major cable lug on the starter.
Observe the voltage while an assistant cranks the starter. The battery does NOT have to be fully charged. Anything more than 0.4 volts displayed is an indication that this cable, or it's connections have developed a high resistance. That's voltage that went "missing" over the trip of the copper cable. It's corroded or failed to the point it can't conduct high starter currents without loss.
What's more, is this effect may not be consistent... it might vary considerably with outside temperature, or how many/how often the vehicle has been started recently. The resistance in such main cables increases with temperature.
Be sure to repeat this test with the battery ground cable or strap, as it can fail the same way. (Voltmeter between battery negative post and the metal starter frame.)
So:
@dlu advice is excellent; this will help decide if your altenator is charging your battery. Given your substitution of other charged batteries, I think the problem lies elsewhere.
"My" test will eliminate or identify the main starter cable as the problem, which although seeming silly, is actually quite common.
The only thing left at that point will be the starter.
    here's a great video explaining voltage drop testing: youtube.com/watch?v=DfLyh43iihM Sep 22, 2016 at 17:36
  • @RobertS.Barnes Excellent; thanks for that. Especially nice example with the starter cable and the exact situation I was trying to describe.
    – SteveRacer
    Sep 22, 2016 at 20:58
If you're hearing a click, it's likely that the starter circuit is receiving electrical current, but a mechanical component inside the starter itself has failed (i.e. starting motor, solenoid etc). Since your car isn't starting, your alternator can't help maintain battery charge, and your constant attempts to start the car, likely with the accessories on, continue to drain your battery.
