Note: Don't know if the question is an adequate fit for this site.
If I see a traffic sign telling me to "Keep in low gear" like the TRAVE COM O MOTOR | Keep in low gear I saw on a Portuguese highway, how can I do it if I drive an electric gearless vehicle, like, for example, a Tesla?
Note: "Trave com o motor" means "Break using the engine|motor" as Portuguese does not have separate words for engine and motor.
  • I think the obvious thing is, you dont. Secondarily, is the sign a requirement or a suggestion? – Pᴀᴜʟsᴛᴇʀ2 Sep 11 '16 at 18:17
  • @dlu: You completely missed the point on your last edit, so I did a rollback. The main point of my question is the fact the driver does not have gears nor any other means of breaking using the engine|motor! – sergiol Sep 18 '16 at 12:10
  • Sergiol - @Paulsters comment is correct here. A) you don't have gears. B) electric cars are quite different to ones with internal combustion engines. You already get regenerative braking, so your comment there is an incorrect assumption. – Rory Alsop Sep 18 '16 at 13:59
  • @RoryAlsop AFAIK, regenerative braking is not breaking using the engine. What regenerative braking does is to get energy of braking into the battery. And yes, you can talk me about the servo brake, but a geared combustion car also has it, so make use of it it is not the goal of that road sign! – sergiol Sep 18 '16 at 17:37
  • Remember, electric cars aren't all that common yet so there are lots of quirks still to be worked out. Some will be worked out in advance, others only as they become issues. – dlu Sep 18 '16 at 18:36
7
Electric vehicles can "engine" brake by using the drive motors as generators. As they generate electricity they consume the car's potential energy - either from speed or elevation or both. The energy can be used to recharge the battery or dissipated as heat. The changeover between power and regenerative (dynamic) braking is usually handled automatically. So in this case I wouldn't expect you'd have to do anything.
| improve this answer | |
