I am replacing the power brake booster on my 2005 Ford Escape V6 3.0 XLT. When I go the new booster in and put the master cylinder on the bolts, the master cylinder was leaning to the left, so it is not level. The bolts are not in the exact same placement. Also, getting the left side brake line back on was a little difficult because the master cylinder was a leaning.
Is this normal? Is it okay?
The original vacuum booster is the one that is out, and the alignment of the bolts angles up the left. The replacement doesn't.
