7
I am trying to replace a corroded cigarette lighter on a Peugeot 206, following this tutorial. As part of this I need to remove the inner metal sleeve up through the orange plastic sleeve:
Peugeot replacement cigarette lighter stock photo
This is apparently achieved by pushing out two retaining clips that connect silver metal to the orange sleeve. On the 206 I'm working on they are completely stuck however whatever I try.
Does anyone have any suggestions on either how to loosen the inner sleeve and take it out or an alternative method to remove the component (which can be destroyed in the process if needed).
It's a very tight space to work in (accessed from under the gear stick boot) so whatever I do will have to be by feel and there's a finite amount of force I can exert at that angle. Help would be appreciated!
  • pull up the trim to get a better angle on it. you will probably have to pull out some screws.
    – Ben
    Sep 9 '16 at 12:02
  • You are looking inside the metal sleeves center seeing the two dog ear locking tangs inside notches in the metal sleeve and pressing them out to separate? A very small screw driver or some times better yet a small offset right angle screwdriver to push them outward works best. Sep 9 '16 at 15:10
  • jaws of life...... :)
    – Old_Fossil
    Sep 9 '16 at 22:50
I revisited this after a few weeks and it turns out that quite a bit of force was needed. I used a claw hammer under the orange outer sleeve to pull it half way out and give myself a bit more access.
half removed cigarette lighter
The inner sleeve was still firmly stuck to the orange one however. I used some WD40 at this point (having previously been a bit worried that it might catch fire if used so avoided it) and a screwdriver to lever out the inner sleeve to the point pictured above, but then it was completely wedged.
I eventually used a pair of long nosed pliers in a twisting motion to snap the outer orange ring and release the tension:
snapped outer sleeve
From there I could remove all the bits very easily, cleaned up the excess WD40 and fitted the replacement. The fuse needed changing as during my levering it had shorted (turns out on my model of 1999 206 the cigarette lighter is always on rather than on the ignition switch).
Interestingly when I got the component out it did not have either of the retaining clips mentioned in that tutorial - it was a one piece unit not designed to be removed. This probably explains why it was so much harder than expected to remove.
