My megane just started running poorly miss firing , loss of power and a horrible fuel smell got it on a diagnostic machine it said camshaft position sensor .Ive just replaced that and its still running bad as anyone got any other ideas what it could be
2does the car have variable valve timing? if so check your oil level it may be low. also if it does the oil control valve may be stuck open. or a cam phaser is stuck. or the cam crank timing ia off. – Ben Sep 8 '16 at 17:54
Check your oil first. Always. Drop a few drips of water on each exhaust pipe to see if you just have a single cylinder misfiring. It may simply be a fouled plug or something specific to a single cylinder. – justinm410 Sep 9 '16 at 18:05
