Over about 1,000 miles the engine develops small amount of oil present from the seal between the cylinder head and engine block. AFAIK it indicates head gasket failing.
The car has been driven for about 5,000 miles, to my knowledge, with this condition.
Does it necessarily indicate a head gasket is failing? Is it possible for the head gasket to fail and the car otherwise operate with relatively few problems?
Does this need to get fixed ASAP. Does it indicate more serious problem?
Close up of leak Showing whole valve cover and more of engine bay
    That could be the cam cover gasket that is leaking which is a much simpler repair. You need to clean the area so that it is clear where the oil is coming from.
    – HandyHowie
    Sep 5, 2016 at 7:12
  • Thanks @HandyHowie for the reply. I only noticed the small amount of oil buildup after hundreds and hundreds of miles. I will clean the area and see if I can get another photo. Sep 5, 2016 at 9:13
From the image, I'd diagnose this as a valve cover (can also be called a cam cover) gasket which is leaking (as HandyHowie suggested in the comment). This is a relatively easy fix on most vehicles, and the engine you show in the picture shows no different to me. What you are seeing is oil/gunk which has built up over time. You don't see this kind of buildup overnight.
As far as how emergent it would be to get this fixed, I'd suggest it's not a huge deal. You could get it done tomorrow, next week, nor next month and not see any serious issues. If you chose to put it off for a little bit, you'd still want to get the area cleaned up (a clean engine runs more efficiently). This will help you to know exactly where the leak is coming from, but I'm pretty sure the cover gasket is your issue. The second thing to know about this is, getting it replaced shouldn't be expensive. This is something most people with any mechanical ability should be able to do on their own. The gasket usually isn't complicated to replace. The biggest "gotcha" would be not to over tighten the cover bolts so you don't squash a new gasket or deform the cover.
  • Could also be the cover it self, I kept changing the gasket several times in my engine and it kept blowing but after changing the whole cover it self it stopped.
    – method
    Sep 5, 2016 at 18:53
  • @method - Yah. If the cover is warped or the flange is bent, it can cause the issue as well. Great fun. Sep 5, 2016 at 18:59
