I bought the bike used and it had a short in the left control and melted it. I bought a new one and the bike has no power in the run position but in the park position it has break lights.
Any ideas on what it could be?
  • My first shot would be to check all fuses and ground connections.
    – jensgram
    Aug 31, 2016 at 5:51
  • Left controls. Do you mean on the handlebar, the 'left controls'? Aug 31, 2016 at 6:49
It sounds like this is your ignition switch. If you are receiving power in the 'park' position on your ignition switch you are clearly getting power to some degree.
There is merit in checking all of your fuses as well.
You can validate various connections using a multimeter to see if you can detect voltage.
Here is a good post regarding multimeters.
