I have just put new risers on my Honda VFR800 and upgraded the pinch bolt for the clip on bars to tritium .
Question:
Do I need to use thread lock?
What torque setting should I use?
  • What is the bolt? M5, m6? If you give the bolt diameter and thread pitch we can tell you the torque value. Aug 28, 2016 at 23:57
Titanium M5 metric bolts have a torque specification of 25 inch pounds.
Yes, you should use thread lock for all handlebar related bolts that are related to your safety as a rider. You can use the lowest level of thread lock.
If you installed an aftermarket handlebar accessory, the manufacturer should list torque specification. Otherwise, you will need to consult the manual.
I recommend using anti-seize on the bolts, not thread locker. Regularly inspect the bolts for any sign of backing out or movement.
