10
I didn't realize until recently that the ATF level is supposed to be checked while the engine is running, unlike the engine oil level which you're supposed to check at least five minutes after shutting the engine off.
I was wondering what the reason is for this discrepancy?
  • My 89 Honda accord is checked with engine off, depends on the vehicle what the engineers specified how to check the level, refer to your owners manual. – Moab Aug 26 '16 at 21:31
12
There are two main things about tranny fluid:
  1. Transmission fluid is checked when it's hot (up to running temperature). As the fluid gets up to temperature it expands. If the fluid is cold, it won't give the proper level reading, thus overfilling will ensue.
  2. One of the main fluid compartments of the transmission is the torque converter. When full, the fluid level of the torque converter is much higher than is the level of the pan (almost entirely above the pan in most cases). Due to this, when the engine is stopped, a significant amount of the fluid will drain down into the pan, showing the wrong amount of fluid on the dipstick. With the engine running, not only is the transmission paths filled with fluid, but the torque converter is as well. Then a check of the fluid will give you a proper level.
Checking engine oil is a lot different. It needs to be checked when it's in the oil pan. In order for it to be in the oil pan, it needs to drain after it's been up in the engine. This takes a little bit of time. Engine oil doesn't expand as much as transmission fluid, so can be checked hot or cold. While engine oil is important to how an engine operates, the level isn't as imperative as transmission fluid. Transmissions are very sensitive to line pressure. As you get more transmission fluid into the transmission, the pressures rise. If left unchecked, the fluid will find an escape hatch somewhere and that somewhere is usually a seal. Blowing out the front main seal (or where the torque converter rides) requires a transmission pull to fix. This isn't something you want to do every day.
Engines don't have the pressure effect which transmissions do. The pressure is regulated at the pump and mainly needs to have oil flow in order to operate efficiently. Most engine manufacturers are good down to even 5psi of oil pressure. There is also a lot of space in an engine for oil to hide. As oil gets pumped around, it sticks to walls and is all over the place. It needs to drain back into the sump, thus the 5 minutes of drain time. Not everything will drain down, but the vast majority of it will. This isn't how every manufacturer likes to have it read, but leaves things in a pretty good state as far as the level goes.
I don't read this as a discrepancy in either case. I look at it as how they are designed/engineered to be checked.
This is specifically dependent on the transmission. There are some that require your vehicle running while you do this. There are some that require you lift the front end up a certain degree and some are required to be non-running.
Why exactly? That's an engineers decision. In your particular situation there are actuators and solenoids that control flow of ATF (automatic transmission fluid) within the transmission. The levels may be incorrect if not observed during active use.
The reason being is that you have a torque converter, ATF cooler, and several veins within your transmission that may only hold fluid during circulation. When the engine isn't spinning and your ATF pumps aren't pumping fluid, it all falls back down to your transmission pan due to gravity. If you check fluid levels when it isn't running it won't read correctly because everything has pooled up in your pan. They also have the cold and dark markers on your stick for the same reason. As fluids heat up molecules tend to spread, so I would assume that the engineers use that as a gauge of correction as well.
I hope this helped. I'm just throwing my two cents in.
    Could you give examples of car transmissions which are checked cold? Because everything I've seen seems to indicate all transmissions are checked running. – Robert S. Barnes Aug 25 '16 at 16:27
  • A good example would be a just like my Hyundai Tiburon 2.7L. They no longer check the fluid running. They actually have a gauge that you attatch to the the top of the tranaxle/ transmission that then reads the pressure and temperature within it. Thus giving you the desired level. Furthermore, I cannot provide outright evidence to my claim. I have been doing this for almost 10 years, and have had to change a lot of tranny fluid haha If you just do a quick google search you might be able to find something on this. The reason my car is like it is, the oil pan and pump are on the front. – cloudnyn3 Aug 25 '16 at 20:11
    @RobertS.Barnes I don't know about checking when cold but some Honda transmissions require checking the fluid level with the engine off and trans fluid hot. Think early 2000's with the 1.7l engine. – Ben Aug 25 '16 at 21:15
  • This answer should have been the accepted solution since it is correct and applies to all manufacturers. – Moab Aug 26 '16 at 21:32
    "Could you give examples of car transmissions which are checked cold?" 1989 Honda Accord is checked with engine off. – Moab Aug 28 '16 at 19:56
Hydraulic oil does not expand, when hot. the air trapped in the oil expands.
the trans oil level lowers when engine is running as the oil is drawn up onto the gears. the level rises when trans is cold, as the oil runs off the gears.
