LDV 2.5 Maxus. Does not start on key, but runs well on easy start. Does the high-pressure fuel pump have a fuse?
Thanks in advance.
Sign up to join this communityThe high pressure pump is not an electric pump, it is powered by the toothed belt. I would suggest you to do the following:
Additional stuff: Check for leaks, abnormal exhaust fumes, rough idling and abnormal engine sounds
