This question already has an answer here:
I'm not worried about the environmental/legal issues. I'm not too worried about the cel being on all the time. Do I need to do anything to protect my engine at this point? Thanks!
marked as duplicate by Jason C, DucatiKiller, tlhIngan, Hennes, SteveRacer Aug 21 '16 at 21:04
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    not really. you might put anti foulers on the rear o2s and see if you can turn off the MIL. – Ben Aug 19 '16 at 11:48
    You can buy a product to simulate the catalytic converters being present so the computer doesn't freak out... urdusa.com/store/Electronics-Rear-Sensor-Simulator/c66_170/… – cory Aug 19 '16 at 13:44
    @Ben I agree - I've also seen them called 'non-fouler' extensions. @ OP I would recommend you get rid of the CEL, otherwise you'll never know if it turns on for a different problem (injectors, timing, airflow sensors, temp sensors, imminent spontaneous combustion of occupant sensor, etc.) – MooseLucifer Aug 19 '16 at 15:00
    @MooseLucifer - Absolutely agree ... full heartedly! – Pᴀᴜʟsᴛᴇʀ2 Aug 19 '16 at 17:08
    +1 on @MooseLucifer's point, you want a functioning CEL, as it warns you about changes in the engine's health. Beyond setting the CEL downstream sensor might be "tweaking" the engine's behavior in ways that aren't optimal. Tuners are likely to be able to tell you what consequences to expect. – dlu Aug 19 '16 at 22:23
If you're not worried about the check engine light (which will more than likely turn on since the 02 sensor will be receiving an excess amount of exhaust reaching it now) or environmental considerations, then removing the cat won't cause any harm to your engine. Some people even believe that driving without a catalytic converter allows the engine to breathe better and utilize more of its horsepower. Be warned though, there are typically laws in place that say a car must have a catalytic converter.
  • "Be warned though, there are typically laws in place that say a car must have a catalytic converter." Not if it didn't originally come with one. – Glen Yates Sep 7 '17 at 14:09
