i have a mazda 323 ZM/ZL engen,i found oil in the radiator after changing the head gasket.it once over heated.
    When got the gasket changed? Did the radiator circuit got flushed afterwards? – Martin Aug 19 '16 at 8:36
  • Who did the head gasket change??? – Moab Aug 26 '16 at 22:34
I can think of a few things off the top of my head. The first would be a bad head gasket. Since your engine overheated it's possible the head was warped which is preventing the gasket from sealing properly. There could be a crack in the head between the water and oil passages and also there could be a problem with the oil cooler.
| improve this answer | |
  • @Moab Could you explain a little more? I'm still somewhat of a novice and don't understand your comment. – Robert S. Barnes Aug 27 '16 at 20:23
