Today I learnt that some engine management setups demand a feedback signal from the ignition coil.
Toyota/Lexus Ignition Diagrams
What does it do with the signal though? Is it just for diagnostics?
Pᴀᴜʟsᴛᴇʀ2's answer is pretty much correct, at least for Toyotas (the linked post in the OP was for a Lexus aka Toyota). Here is some extra detail. Also "feedback" is used for different things in different ignition systems.
Toyota/Lexus (Catalytic Converter Overheat Protection):
This is from the official coursebook for Toyota's EFI/TCCS training course #850:
Spark Confirmation IGf
Once a spark event takes place, an ignition confirmation signal called IGf is generated by the igniter and sent to the ECU. The IGf signal tells the ECU that a spark event has actually occurred. In the event of an ignition fault, after approximately eight to eleven IGt signals are sent to the igniter without receiving an IGf confirmation, the ECU will enter a fail-safe mode, shutting down the injectors to prevent potential catalyst overheating.
Later, in the chapter summary, it once again states:
An ignition confirmation signal is generated by the igniter which signals the ECU with each ignition event. The IGf signal is used to provide the ECU with a fail-safe fuel cutoff if ignition spark is lost.
So this directly states the primary purpose:
  • To let the ECU cut fuel if a spark plug stops firing, for the express purpose of preventing unburnt fuel from overheating the catalytic converter.
The question the OP linked to confirms fuel-injector cut after nine missed confirmations (you can see it in the scope output), just as the description from the coursebook states. We can only conjecture why it keeps firing anyways - my personal theory is since it's primary goal is to prevent catalyst overheating from unburnt fuel, it just gives it periodic breaks then continues to retry, but it could also just be your everyday limp mode bouncing around at an RPM cutoff point. Or it could be smart enough to say "OK, since every igniter is failing to respond, maybe something else is going on and the coils still work". I mean; really, there's plenty of good reasons to cut the fuel injectors, but not really any great reasons to cut the spark plugs, so why not just keep going (the real question there is probably "why do the fuel injectors resume" rather than "why do the spark plugs continue to fire", but now we're straying). Who knows. Doesn't matter though, the purpose is clear at least.
Now, from that, we can also infer some secondary purposes, or at least nice obvious side-effects:
  • To provide a technician with valuable diagnostics info (pretty convenient when the car just tells you that there's an issue in cylinder 3's coil or whatever).
  • To provide the vehicle owner with valuable feedback (i.e. turn on the CEL, time to go to the shop).
Ford (Dwell Control):
It's worth noting that the above was Toyota-specific. For example, Ford has a patent on a feedback-based dwell control system:
These were filed in 1990 and therefore expired in 2004 (when it presumably became available for others to use).
In this system, consider a possible initial state (pre-dwell corrected) of a coil charging mechanism:
Here, current is sent to the coil. There's the initial charge time, but then the dwell is too long and so there's a delay before discharge. Also the spark timing is too late, because it took time for the coil to charge. So you add the feedback signal (Fig. 1C above), which goes low when the ignition signal is received, and high when the coil is charged.
Now the ECU knows exactly how long it takes to charge a given ignition coil, and can make corrections to the dwell time, and offset the ignition commands as well, allowing the ECU to start charging the coils far enough ahead of time so that the actual discharge (spark) happens exactly when it should:
And the big advantage of this over a "hard-coded" dwell time is the ability to adjust to the current conditions of the environment and ignition coils, in real time, while maintaining precise spark timing.
It's entirely possible that vehicles after 2004 used this system since the patent expired.
And of course in addition to the dwell correction we still get the diagnostics benefits here.
There are some related patents as well (and probably more):
  • Ford, EP 0390314 A2, describes a timing offset system based on back-EMF.
  • Toyota, EP 0350894 A2, which I've included just because it's interesting. This describes a non-feedback-based system with a similar goal which attempts to correct spark timing by predicting when the next TDC will occur.
These were all filed around the same time in the late 80's and early 90's, it looks like there was probably a big patent rush for ignition timing control systems. I'm sure the lawyers and engineers in all those ignition system labs were consuming inordinately large amounts of coffee during that time period.
Ford (Dwell Control + Pre-ionization):
So the above Ford patent was filed in 1990 and expired in 2004. There is a newer Ford patent, filed in 2009, which builds off of it:
This patent describes the same dwell control system, but also includes some sort of pre-charge phase that can detect pre-ignition or fouled spark plugs. It looks pretty cool, but since this answer is already so long and this patent rabbit hole is virtually bottomless, I have to cut myself off here, but you can read more about it there.
Further Reading:
Basically, there's a lot of uses for feedback from the ignition coils in general. Various systems use it for various things so it's not really possible to give a general answer beyond "it lets the ECU know when the spark plugs fire, so that it can do nice things".
I'm sure many other companies besides Ford and Toyota have a lot of other interesting things that they do with feedback signals from ignition coils.
There's tons of further reading. If you've got time, just start going through the citation lists from the patents linked above. Everything you've ever wanted to know about every ignition control system that has ever existed should be there somewhere, so have fun.
|improve this answer|||||
  • PS. Theoretically, it's even possible that the Lexus uses, say, the average pulse-width of all the IGF signals to do a global timing offset correction, or whatever else. Dunno. Further research may yield even more info, but basically, there's a lot of things that can be done with the feedback. – Jason C Aug 12 '16 at 23:59
  • Nice writeup! You deserve the check after doing this legwork :o) – Pᴀᴜʟsᴛᴇʀ2 Aug 13 '16 at 13:19
The ignition confirmation signal is a comeback signal to the ECM. This tells the computer a successful spark has occurred: the coil has launched it's goods. When the signal fails, the computer knows there's an issue with the coil or the ignition circuit and will send a fault code, then notify the driver with the glorious check engine light.
  • CEL shudder - It gives me the same deep sinking feeling as those mysterious red and blue flashing lights. – MooseLucifer Aug 12 '16 at 14:32
  • If you see the linked question, it is possible for the coil to spark but not return the feedback signal. That's why I'm curious to know why the ECM should bother with receiving feedback in the first place. Do fuel injectors issue a similar feedback signal to the ECM? I'm not aware that they do, and if injectors don't issue a feedback signal, why should a coil do so? – Zaid Aug 12 '16 at 14:41
  • @Zaid - I think there's a flaw in your injector to coil analogy. The coil is active while the injector is not. While both are firing, the coil has the igniter, which has rudimentary electronics within and can give feedback. The injector is just on/off. To me, the coil is smart (in a sense), the injector is dumb. If they were smart, you'd probably see them give a signal back as well. – Pᴀᴜʟsᴛᴇʀ2 Aug 12 '16 at 15:15
    @Zaid Yeah, it's possible for the coils to spark, but in the linked question, the ECM threw the car into limp mode probably because it wasn't receiving the confirmation. It would be reasonable for the ECM to keep sending firing commands anyways in the absence of a confirmation response because that has the highest chance of at least keeping the vehicle driveable during wiring issues. The feedback is probably more for the driver's benefit, to politely notify them if a coil is failing, but if they all fail I could see why an ECM would become suspicious and go into limp mode. – Jason C Aug 12 '16 at 15:16
  • @JasonC In the linked question the car presumably goes into limp mode because it doesn't receive feedback, yet the ECM has no problem in continuing to issue the signal in the hope that the car runs. I would imagine that the engine management is using the feedback for something and goes into limp mode because it doesn't get it. If the only use of this signal is to notify the ECM of a properly functioning coil then it seems like overkill to have the car go into limp mode. I guess we need to understand what triggers the limp mode in that particular car. – Zaid Aug 12 '16 at 18:34
There's a still from this ScannerDanner video, which says the following regarding a 1991 Toyota:
Primary circuit is turned off when the ECU sends a signal to the ignitor on the IGT wire. At the same time, the ignitor sends an IGF signal to the ECU. The ECU feeds voltage to the IGF circuit. The ground for this voltage is momentarily cut when the primary circuit is turned off. The ECU monitors the IGF signal and detects if the primary was switched on and off. After sending a command to turn off the primary circuit on the IGT wire, the ECU monitors the IGF circuit to ensure primary switching occurred.
So it is a confirmation for the engine management that the primary circuit pulsed on/off as expected.
