If I were to remove the fuel pump fuse on a Hyundai i30 CRDi diesel and then try to start the engine, would I need to bleed the fuel line or would it be okay?
Asked
Viewed
573 times
What's make/model/engine of the vehicle in question? – Pᴀᴜʟsᴛᴇʀ2♦ Aug 6 '16 at 11:30
2013 Hyundai i30 ctdi. Any help appreciated! – Gary Hitchens Aug 6 '16 at 11:37
1I don't have any experience with the Hyundai ctdi engines, but would assume since you are not breaking open any lines, you'll not have an issue with needing to bleed them after pulling the fuel pump fuse. I believe most newer diesel cars have a return style diesel system which doesn't need bleeding even if you break open a line. I don't think you'll have issues, but would suggest you wait for a more authoritative answer than my comment. – Pᴀᴜʟsᴛᴇʀ2♦ Aug 6 '16 at 12:38
Crank with fuse removed? – dlu Aug 6 '16 at 18:02
