I've tried a lot but I couldn't get a clue, this is the only picture I could get.
The seller mentioned it was a 60's "dihatsu", but I couldn't get to be sure. Also I need help with its body tuning ideas, and how easy would it be to get it to look like a 70's ford mustang ?
car's only available picture
8
  • need picture from front and back also, ask the seller for them.
    – Moab
    Aug 5, 2016 at 20:56
    Welcome to the site. We really need you to focus on a question here. The way you have it, it's very broad, meaning, there's way too much to answer. Can you pick a starting place and rewrite your question, then ask subsequent questions building upon the first? Aug 5, 2016 at 21:05
  • Daihatsu does not appear to have ever made a vehicle that looks like this, certainly not in the 60's. So if it's truly a Daihatsu, it's been heavily modified - I mean, maybe it's a '69 Consorte with a modified rear-end, although I can't tell from the picture. You'll have to ask the seller. As for "how easy would it be to get it to look like a Mustang"... not really sure what kind of answer you're looking for to "how easy". Anywhere from "no problem" to "impossible" based on your motivation, creativity, skill set, and tools.
    – Jason C
    Aug 5, 2016 at 21:25
  • @JasonC thank you , it's very unlikely to be modified . Aug 5, 2016 at 21:45
  • @Pᴀᴜʟsᴛᴇʀ2 , What is this car's name ? Aug 5, 2016 at 21:45
Looking at images, if I had to guess, I'd suggest you are looking at a 1974-ish 120Y (or B210 in the States) coupe. The one in this picture is from Australia, or at least that's what it says on Wikipedia.
  • You think it's a Datsun? It does have a similar window layout, although the front bumper is a bit off, so is the keyhole relative to the door handle. Closest guess so far though. I couldn't find any similar looking Daihatsus or Toyotas from the era.
    – Jason C
    Aug 5, 2016 at 22:05
    @JasonC - Look at the body line over the wheel arches and down the bottom. Then look at the back glass and the c-pillar angle. Look at how the wheels look in the arches. Look at the top and the angle of the back. And if you look at the lock location, it's spot on ... the angle of the photos throws it off. I'd give it about a 95% probability this is the car in the picture. Aug 5, 2016 at 22:08
  • Yeah; I see. I'd give it 95% too. Or maybe a 3rd gen Sunny Coupe, part of that same series (early - mid '70s). I'm still suspicious of that front bumper. Can't explain the doors; the keyhole is below the ridge in the OP's pic. And there's no curve in that rear window corner. Maybe it's some kind of slight variant that you don't see in common internet pics, or had some work done unknown to the seller. +1 way better than what I found.
    – Jason C
    Aug 5, 2016 at 22:11
  • @JasonC - The front bumper doesn't look stock to me. Also, take into account the car in the OP's question is beat to crap, whereas the one in my picture is nearly pristine. The grill on the C-pillar is gone. There's no vinyl top on it, and there isn't enough detail in the OP pic to make out the body line which you can see in my picture (center of door panel you talk about). Aug 5, 2016 at 22:19
  • @JasonC - I see what you're saying about the lock, now. Thanks for pointing it out. Aug 5, 2016 at 22:22
The closest I can find is a 1973 Toyota Liftback 2000 GT. But I don't think it is. Maybe there are other manufacturers around the same time building similar cars?
