I have an '04 Infiniti G35 6MT coupe, 97k miles, completely stock. I'd like to install a catch can to help diagnose and possibly reduce some oil consumption (Previous question with more details on oil consumption).
I'm losing 1 qt every 1400 miles. Never smokes blue or otherwise, runs smooth, pulls strong. I've tried Mobil1 5w30, Castrol Edge 0w30 and changing the PCV valve. Oil loss rate has remained steady. I've ruled out any external leaks.
I've seen a few ways this or other PCV modifications are done:
  1. Sealed can between the PCV valve and the vacuum inlet on the manifold. This theoretically draws most of the nasty stuff out into the can and returns clean-ish vapours to the manifold. I expect this probably won't have much effect on consumption, but I'll be able to say, "yup, that's where my oil is going." The only potential problem I see with this is possibly a slight reduction in the vacuum on PCV (due to it having to travel through the can and additional plumbing), adding more stress to seals.
  2. Pulling the PCV valve, plumbing it to a vented can intake, and plumbing the other side of the can to the fresh air inlet. The vacuum inlet on the manifold and fresh air outlet on the intake duct would be capped. This has reportedly seen some success in greatly reducing oil consumption, but having no vacuum on the PCV and only getting fresh-ish, unmetered air on the inlet seems like a potentially Bad Idea™.
  3. Breather directly on the PCV port (no valve) and cap the vacuum port. Obviously, no vacuum and possibly changes the metering a bit. Still seems like an iffy idea.
What is generally the best setup for this? Are there other possibilities?
  • #1 and #3 are clear and common, but I'm not sure I understand #2, is there a diagram? How does it reduce oil consumption? Aug 3, 2016 at 10:54
  • @IhavenoideawhatI'mdoing from what I understood it was the same as #1, except the can has a vent, so the vacuum introduces fresh air into the system through said vent, but the pressure drop across the can (caused by the vent) catches virtually all the oil that is extracted from the crankcase. Aug 3, 2016 at 14:17
    @ihavenoideawhatimdoing, see: youtube.com/watch?v=1KuTMN1YbRE ... the vacuum inlet port on the manifold and the fresh air outlet port on the intake duct are capped. The output from the catch can is routed to the PCV fresh air inlet. The theory is that removing (or reducing) vacuum prevents it from drawing on the PCV excessively. Aug 3, 2016 at 16:27
EDIT: Pictures of my setup. I think I used 24" of high pressure hose total, and my canister happens to sit nicely behind the bracket that holds the PS reservoir.
I have an '06 G35 6sp Sedan (145k miles). I installed a catch can using the first method you listed, by adding it in line with the existing PCV valve<->intake plenum.
For your application, I'd say that would be the best method, as a sealed system will give you the best idea how much oil you're losing through the PCV. My reasoning for installing a catch can (besides wanting another project to do) was to keep hot oil out of the intake plenum since I had also installed a modified lower plenum, plenum spacer, aramid gasket, SRI, and copper TB spacer, which made a noticeable difference in plenum temperature. Having again removed the upper plenum after 10k with the catch can, I was pleased to see the plenum was still more or less oil free vs when I took the original plenum out (see picture below).
I was surprised how much oil I 'caught' after installing the can. I empty it every couple weeks (500-700 miles) and it's usually getting close to full (150 mL), unfortunately that's nowhere near the half quart (1000ish mL) you're losing every 700 miles, but it'd still be worth looking in to.
If you haven't changed your spark plugs, crumbling valve cover gaskets that leak into the spark plug wells were a common problem on the 05-06 VQ35DE REV-UP engines, so it probably wouldn't be a bad idea to at least pull the ignition coils and check them for oil.
These engines are known to last, so I'd be surprised if it was a head gasket or piston rings, though it's probably also worth checking if your coolant is cloudy.
Good luck!
Below is the old lower plenum after 85k miles without a catch can. It's not a great photo, but you can see the oil residue in front of and on top of the runners. When the clean plenum was installed and run 10k with a catch can, it still relatively new (thin film of oil in the vally that's inside the runner in the bottom right of the picture).
  • Great info, thanks! Do you have any pictures of the can installed in the engine bay? Everything's a tight fit on this car, trying to figure out where it'll work. Aug 3, 2016 at 5:25
  • @RecoveringNerdaholic Pictures added! Also I didn't realize you were the same person with the previous G35 oil consumption question. Sorry we couldn't be of more help, but way to be proactive! I edited the link to the old question into this question since it's related. Aug 3, 2016 at 14:36
  • yeah sorry, I should've linked that thread. Thanks for the pics! What size can is that? I'm hoping to find one with a level indicator. Aug 3, 2016 at 16:34
  • @RecoveringNerdaholic Not sure the size, it looked a little smaller than the pictures of 150mL so I assumed 100. This is the one I bought: amazon.com/gp/product/B0057D8LII/… Aug 3, 2016 at 16:37
Catch cans are common on modified turbo engines (they sell kits), what you suggest is the way to do it. Most catch cans have a drain in the bottom so you can drain the can and see how much oil is being pushed through the pvc system over a given amount of engine run time.
The only reason to vent it through a pvc valve into the intake is for emissions purposes, you can eliminate the pcv and dump it into a vented can if you wish.
  • Thanks. I guess I'm looking to find out which setup is best and whether my concerns about each option are warranted. Aug 2, 2016 at 20:52
  • @RecoveringNerdaholic I had bad luck with the drain type cans. I tried a used then a new one, and both leaked everywhere. Ended up getting a locking type where the entire canister twists off from the top, rather than drains from the bottom. This way you can also remove the filter if you prefer. Aug 3, 2016 at 14:23
