I have a 2004 Honda Odyssey. Yesterday, it starting having an issue where it would no longer start. The engine would not even crank, but there did not appear to be a battery or battery connection issue as lights, radio, et al still worked and did not seem to dim or be affected when key turned to crank/start position.
After some trial and error, checking battery cables, etc, I noticed that when the key was moved to the ON position, the D light on the transmission dash indicator remained lit for a few seconds and I could hear what sounded like a motor running or buzzing of some sort for about 2 seconds. Once that stops and the light goes off, then I can turn the key to the start/crank position and the engine will start fine.
It didn't do this until yesterday. What might be failing or going wrong?
The buzzing you are hearing is the fuel pump priming/pressurizing the fuel system, this is a normal sound. Most people don't hear it because the engine is normally in the process of starting at that time.
The D light suggests the PCM has detected an issue related to the transmission and may have a trouble code stored. Get the code read.
  • Have a dealer appt on Friday. We'll see what the outcome is.
    – BBlake
    Aug 2, 2016 at 17:45
Turns out it was the starter motor that had died. We had it replaced and everything's good again. The D light was apparently a mistaken symptom. They said there were no issues with the transmission.
