Pretty much all in the subject...the level jack lights stay on even when fully retracted, which I think is a sign of low fluid levels. I've got the hydraulic fluid, but I can't figure out where in the $(*&%$ to refill it.
TIA.
The reservoir should be underneath the chassis - follow a hydraulic line from one of the levelers back to its source.
Fill plug should near the top.
I found my hydraulic reservoir for 2000 southwind fleetwood behind passenger tire (behind mudflap). It's tight and crammy and I had to sit straight up with little to no space to work with. Absolutely one of the worst things I would like to avoid doing again but let's face it...It's inevitable lol.
