Like most of us I have dealt with steel rust on many occasions, but how should I deal with aluminium corrosion bubbles under the paint?
I have just bought my first aluminium car, which are becoming a lot more common now. The bonnet has a few stone chips which have started to bubble.
On a steel car one would sand back, use a rust treatment (krust for example) and then fill / paint.
But How should I "Kill" the aluminium oxidation?
Same as steel panels, only if you use wire disc on angle grinder, use a softer brush. Everything else the same.
| improve this answer | |
    but rust-converters are made for steel, not ally – Digital Lightcraft Jul 27 '16 at 19:21
  • @DigitalLightcraft Wire brush -> fill + paint. If you're expecting to convert the alumina back to aluminum you're not going to find a reasonable chemical treatment to do that. You just have to remove it then either hide or fill any resulting pits. – Jason C Jul 27 '16 at 19:43
    Sorry, didn't really think of rust converters.. I just never used them, I always grind everything physically out and buy a high quality primer. – Arturs Bolsunovskis Jul 27 '16 at 19:46
